Pros and Cons of a Folding Work Bench
If you are considering purchasing a folding work bench for your garage, shop or basement work area, there are several pros and cons you should be aware of. While a folding workbench is a great idea for many applications, there may be a few things you read below that make it less attractive of a purchase.
Pros of a Folding Work Bench
Here are several positive aspects to purchasing a folding work bench.
Lightweight. A folding work bench is a great lightweight option. It can be moved easily from one location to another.
Easy to Set up. A folding work bench is very easy to set up. It usually requires only a screw driver and an ability to unpack a box. A folding work bench can usually be setup in less than a half an hour and ready for full use.
Inexpensive. Most folding work benches are less expensive than a full blown steel work bench. If you are trying to stay within a tight budget, then purchasing a folding work bench may be the best option
Here are several of the cons to purchasing a folding work bench
Not Easily Adjustable. If you need a work bench to conform to certain height requirements, this may not be the best option for you. A folding work bench is usually only geared to specific heights and lengths.
Flimsy Storage. The storage solution for a folding work bench is usually not as sound or sturdy as a standard steel work bench.
