Pros and Cons of a Garage Ceiling Pulley Storage System
A garage ceiling surface can be used to store many different tools and items. Many home owners traditionally add ceiling mounted storage units. These units help to store boxes, lawn and landscaping equipment and other materials and tools that do not get used frequently. Another option, is adding a pulley hoist system along with different adjustable racks for storing. Below are a few pros and cons about this type of system.
The Pros of Pulley Storage
The pulley system really does take the effort out of storing things away. You will never have to lift a heavy load of boxes or items again. The pulley system also saves you from climbing up and down from the ladders. So safety is definitely maintained by the system.
The Cons of Pulley Storage
Sometimes homeowners are more anxious to store lots of items up on the pulley system and they forget that the system has a maximum weight limit. Many average systems are only good to store up to 200 pounds of weight. Going over this limit will cause harm to the people and cars below.
The system also has its own set of safety problems you must be aware of. If you fail to properly secure the item you are lifting upwards, you may end up having it crash down back onto you.
Last but not least, the pulley system is electronic and electronics do fail at one time or other. You could end up having a whole bunch of things up in the rafters without any way of getting them back down on the floor, without replacing the mechanisms.
