Pros and Cons of a Raised Tile Floor
A raised tile floor can be a useful feature in your home. Raised flooring is an elevated floor that extends beyond the original floor. The height of a raised floor can range from a couple of feet to several feet. Several square removable panels supported by various understructure systems are used to achieve this raised effect. Raised flooring has been widely used in offices, especially data and IT centers. It enables more efficient wiring, improves access and enhances productivity. Below are some of the benefits and disadvantages of a raised tile floor for homeowners.
Pros of a Raised Tile Floor
Raised tile floors can be constructed just about anywhere in the house. You can achieved the raised effect in the basement, living room, bathroom or wherever else desired. Tiles used on raised flooring enhance the beauty of the room. You can get tiles in a virtually unlimited variety of colors, sizes, shapes, styles, patterns and textures. Elevated tile floors are a good way to boost your home décor. They enhance the functional aspect of your house. You are able to develop new usage areas without being limited by space. This is especially welcome if space may be a problem in your home. Enhanced functional value adds to the value of your home.
Tiles tend to be cold on the feet when used on the sub-floor. However, a raised tile floor feels warmer due to the thermal insulation effect. They are more comfortable to walk on than a tiled sub-floor. Raised flooring enables home repairs and maintenance to be undertaken with greater ease. Wiring and plumbing can be a challenging job with ordinary floors. Raised floors allow easier access to water and electric points. This allows for a more efficient repair or maintenance job.
Environmental concerns are a top priority these days. Raised flooring allows you to integrate green values in your home construction. A raised floor promotes energy savings. Thermal insulation is enabled by the space between the raised floor and lower floor. Integrating design techniques that boost energy efficiency boosts the resale value of your home. Construction of a raised tile floor is less costly than building a floor on the original housing foundation. It is a cost-effective way of developing your house.
Specialized knowledge and tools are involved for proper installation. These may be beyond your reach. Installation is best done by a qualified home contractor. This will assure you of more satisfactory results. However, it adds to your overall home improvement costs. Unfortunately, tiles are subject to breakage and chipping, whether used on a sub-floor or raised floor. Also, the durability of tiles is not as high as some other materials. It is best to replace damaged tiles as soon as you can. If not, the damaged area spoils the beauty of the entire floor. Replacement of tiles adds to your overall home improvement costs. Tiles can be noisy which may cause some irritation if you prefer a quiet home environment.
