Login Error
Close
Pros and Cons of a Vinyl Deck Railing
by DoItYourself Staff
If you are considering adding decking to your home, you might consider finishing the look with vinyl deck railing. Compared to expensive woods or custom made metal railings, vinyl may not be the most attractive choice, but they still have some advantages that should be considered.
Advantages of Vinyl Deck Railing
The first advantage is the cost. Vinyl deck railings are much cheaper than either wood or metal versions. If you are working on a tight budget, a vinyl deck railing set could be a good idea. They are also easy to install, and you can then paint them to achieve the look you want, making vinyl an excellent choice if you want to do it all yourself.
Disadvantages of Vinyl Deck Railing
Vinyl deck railing is cheap and cheerful, and this is often reflected in the lack of durability of the railing. It can sometimes start to peel or split after a few years, meaning that you have to replace it far more often than its wooden or metal contemporaries. In addition, it is very obviously vinyl in most cases, making it look less appealing compared to wood.
 forum activity
