Pros and Cons of a Wallpapered Kitchen Backsplash
Installing a wallpapered kitchen backsplash is a fast, economical and creative way to brighten and add color to your kitchen decor. Wallpapered kitchen backsplashes do have both pros and cons, however, so read on to find out about the upsides and downsides of covering your kitchen backsplash in wallpaper. Your wallpapered kitchen backsplach will be unique thanks to the wide range of wallpaper styles and patterns available. It is simple to install a wallpapered kitchen backsplash thanks to self-adhesive wallpapers. Compared to tile, stone, laminate, glass, mirrored or metal backsplash materials, wallpaper is among the most economical choices for a kitchen backsplash. You can choose from a vast array of wallpapers for your kitchen backsplash. Select a wallpaper that will work with existing countertop, hardware and cabinet colors. Take one of your cabinet drawers to the wallpaper shop to help find complementary colors and textures. For a contemporary kitchen choose a mod design with a geometric pattern of circles, squares or asymmetrical lines. For a country kitchen, select a vegetable, flower, herb or farm animal motif. In a modern kitchen, apply a clean stripe, dot, or textured surface like grasscloth, linen. If you like, you can choose a design that mimics a tile, brick or stone surface. Buy wallpaper for your kitchen that is made for bathrooms, as it will do the best job at resisting moisture and preventing mold buildup. Install the wallpaper over as large a surface area behind the sink, rangetop and other appliances as you can. Be sure to cover at least 1/4 of the room's wall area to create a unified appearance. Match patterns carefully when applying the wallpaper, as errors will be magnified in small areas and at corners. You may be able to buy a wallpaper remnant roll to do your kitchen backsplash. Buy at least 1 yard more than your measured square footage or fitting around corners and between countertops and window ledges to provide for pattern matching. The downsides of wallpaper as a kitchen backsplash material are low durability and potential difficulty of cleaning stains and splatters off the backsplash. Even the strongest wallpaper self-adhesive may come loose after repeated exposure to humidity and heat, especially near the stovetop and oven. You can repair peeling wallpaper with a waterproof epoxy glue. Allow the glued portions to set for 12 hours before exposing them to heat or moisture again. Even some scrubbable wallpapers may not be able to withstand regular cleaning with harsh cleansers and spray cleaners. The wallpaper may peel or even fade in spots. If you have purchased extra yardage you may be able to replace strips as needed, or apply them right over the damaged strips. Prevent spots and stains from forming on your wallpapered backsplash by cooking food in pots with partial or full lid coverage at all times. Wipe down the backsplash behind the kitchen sink frequently to prevent adhesive peel-off.Pros of a Wallpapered Kitchen Backsplash
Color and Design
Installing Wallpaper on a Kitchen Backsplash
Frugal and Fashionable
Durability of Wallpapered Kitchen Backsplash
Cleaning a Wallpapered Kitchen Backsplash
