Pros and Cons of Airless Fence Painting Sprayers
Painting a fence might seem a tedious task, but an airless fence painting sprayer will relieve you of hours of work. The finish on your painted fence will be close to flawless. Read on to learn more about the pros and cons of airless fence painting sprayers. Airless fence paint sprayers pump the paint out through a very small vent, to produce micro-droplets. Because the paint is less affected by gravity in this small liquid droplet size, it goes on more smoothly and does not clump at the bottom of the fence planks or posts. If you are painting near garden plants, shrubs and lawn furniture, cover them with newspaper or light cotton drop sheets. These electric airless sprayers, because they are not powered by a noisy air compressor, are almost as quiet as an old-fashioned paintbrush. The paint application is controlled by your hand movement, so the more evenly and smoothly you move the paint nozzle, the more uniform your final paint coating will be. Many airless paint sprayers come equipped with a reversible spray nozzle. If one side of the nozzle becomes clogged, you can quickly take it out, clear the clog, turn it around to the other side, reinsert it into the sprayer and resume painting. The airless fence paint sprayer covers a wide section with each spray, saving time and paint. Using an airless fence painting sprayer can become tiring to your wrist and hand because you must keep your hand moving all the time you are pressing the sprayer trigger. In fact, you must move your hand before you press the paint sprayer's trigger. The motion of your hand assists in feeding the paint evenly to the spray nozzle. To stop painting, you must first release the spray trigger, then stop the movement of your hand. Airless fence painting sprayers can only spray smooth latex or oil-based paints. They cannot apply paints that have texture or grit for traction. You cannot leave paint in the sprayer overnight and come back to resume painting the next day. As soon as you have turned off and unplugged the fence painting sprayer, empty the sprayer and thoroughly clean the paint reservoir, connection hose, trigger and spray nozzle. Airless fence painting sprayers operate under very high pressure. You can cause an injury to yourself or others by simply directing the paint sprayer at exposed skin. The paint can penetrate the top layer of skin even if there is no visible cut or scrape. This is called a fluid injection wound, and you must seek medical care at once. Always release the pressure with the prime valve of the sprayer every time you turn off the sprayer. Be sure to clear the nozzle by spraying with the sprayer into an empty bucket. Whether painting indoors or outside, wear lightweight coveralls, a spray hood, safety goggles, and a breathing respirator.How an Airless Fence Painting Sprayer Works
Pros of Airless Fence Painting Sprayers
Cons of Airless Fence Paint Sprayers - Constant Hand Motion
Limited Paint Types
Empty and Clean the Sprayer After Each Use
Safety Tips
