Login Error
Close
Pros and Cons of Aluminum Gutter Installation
by DoItYourself Staff
If you are considering aluminum gutter installation there are a few things that you will want to know first. Here is a little information to help you decide if aluminum is the best material for you.
Installation Process
Aluminum is very easy to install. You can use clips that go down the length of your gutter and help to attach them to your roof. They also allow for expansion from the weather.
Preventing Seams
One downside to aluminum is that while you can find seamless gutters, many times you will need a professional to install them. If you install yourself, you will most likely have seams.
Aluminum Stability
Aluminum gutters can be found in a thick material and are extremely durable. They tend to expand much less than other material options. However the downside is that they are more prone to denting.
Easy to Paint
Aluminum is easy to paint by yourself if you are trying to make your gutters blend in with your home. You can also custom design and order aluminum to fit the style that you are looking for. Typically you can find a color option in any budget.
Easy Maintenance
Aluminum gutters are very easy to maintain. Dents can be removed easily with a hammer and besides the typical cleaning, this type of gutter can pretty much be left to itself.
The bottom line is that aluminum gutters are a great way to go. They are easy to maintain, paint, install and they are pretty inexpensive.
 forum activity
