Login Error
Close
Pros and Cons of Asphalt Rolled Roofing
by DoItYourself Staff
Asphalt rolled roofing is a very popular roofing material that is commonly used in the building market. This type of review material presents you with a number of benefits as well as drawbacks. Here are a few of the pros and cons associated with asphalt rolled roofing.
Pros of Asphalt Rolled Roofing
  • Cost: One of the best things about this type of roofing material is that it is not that expensive. Compared to other types of roofing, asphalt rolled roofing is going to be one of your cheaper options. If you are trying to work within a budget, this can be very valuable.
  • Installation: This is also one of the easier types of roofing to install. You roll it in place and it goes together quickly compared to other types of roofing.
  • Short life expectancy: This type of roofing does not have a very long life expectancy compared to other types. Most of the time, you will be able to get about 10 years out of this roofing product. Then you will have to replace it.
  • Seam issues: Since this product is rolled out and stuck together at the seams, this often causes problems where the rolls join. This increases the need for repairs and maintenance over the lifespan of the product.
 forum activity
