Pros and Cons of Ceramic Tile Countertops in the Kitchen
Popular ceramic tile countertops in the kitchen provide many advantages and disadvantages. Consider the following pros and cons of ceramic tile countertops before you decide to install them in your kitchen.
Looks
One of the big advantages of this type of countertop is that it has a beautiful look. If the tile is properly installed, it will create a very elegant look in the kitchen area. With this type of counter, you can completely customize the look. A talented installer can create patterns and designs on the counter with the tile. You can use different colors and decorative tile pieces to make the countertop look unique. There are also many different textures that you can use to change the look and match any decorative scheme.
Cost
Another benefit of using this type of tile on your countertop is that it is not very expensive. Compared to a granite or quartz slab, you will be able to save hundreds or thousands of dollars. When you factor in the long-term costs, this option is ideal. You should not have to replace it for many years, which can save you money over the long run.
Cracking
One of the big problems that people have with ceramic tile countertops is the cracking. Ceramic tile can crack if you drop something heavy on it, like a cast-iron skillet. If someone leans on the edge of a counter that is not supported properly, it could crack the tile as well. When tile cracks, there is nothing that you can do to repair it. You will have to take out the broken tile and put another one in its place. While this is possible, it can be very difficult to find a replacement. You will not be able to find the exact same tile unless you kept one from the original installation. If you get a new tile to replace it, it will be a slightly different color or style.
Grout Joints
Another problem that many people have with ceramic tile countertops in the kitchen is the grout joints between the tiles. Grout joints can be very hard to maintain, especially when you are constantly spilling liquids on them. You will need to make sure that the grout joints are sealed every year or so. If you spill something on the grout, you need to wipe it up immediately so that the liquid does not stain it.
The grout joints in between the tiles also make it difficult to clean the countertop. Little pieces of food can get stuck down in between the tiles, and the surface is not level enough to simply wipe down with a rag. This can add to the time that it takes to really get and keep your counter clean.
