Pros and Cons of Cork Flooring Underlayment
Installing cork flooring underlayment is a necessary part of the process of installing floating cork flooring. The underlayment provides several benefits to the cork and those that walk on it, however, there are some drawbacks associated with it. Here are a few pros and cons of cork flooring underlayment.
Pros
- Sound protection--One of the best things about cork flooring underlayment is that it makes the flooring even quieter to walk on. Cork is naturally quiet anyway, but this makes it that much better.
- Prevents joint damage--The main purpose of putting underlayment under the cork is to prevent the joints between the boards from cracking. If you walked on cork without a pad underneath, it would soon break apart.
Softness--Underlayment also provides a slightly softer surface to walk on, which helps your joints over time.
Cons
- Added expense--When you buy flooring, you will soon realize just how expensive it can get. Adding something else besides the flooring just adds more money to the total bill. While it is necessary, it can help increase the amount of money that you pay for the flooring project.
- Added work--Another disadvantage of cork flooring underlayment is the extra work that it takes to install. While it is a simple process, it does add more time to the job.
