Login Error
Close
Pros and Cons of Corrugated Steel Siding
by DoItYourself Staff
Corrugated steel siding is an excellent choice for home siding needs. You will spot many homes with the familiar wavelike pattern of corrugated steel. Various materials are available on the market for siding purposes. Plastic, wood, asphalt, brick, asbestos and metal are commonly used for siding purposes. Steel is one of the best metal choices you can make for your siding needs. It is helpful if you know both the advantages and disadvantages of steel siding. This will enable you to make a good choice.
Pros of Corrugated Steel Siding
Steel is highly durable. It has been used for thousands of years. It has a high resilience and does not damage easily. The waves on corrugated steel boost the durability of the siding. Corrugated steel is an excellent defense for your home against the weather. It fortifies your home in a way that few other materials can match up to. It takes a lot of force to destroy steel siding. Steel is resistant to fire, weather, rot and bugs. Steel is not affected by hail, unlike some weaker metals such as aluminum. Corrugated steel has one of the highest dent resistance qualities to hailstorms. This is important if you live in an area that frequently experiences hailstorms.
Corrugated steel requires minimal maintenance yet will retain its appearance for several years. It is also one of the more cost-effective materials available for siding purposes. It costs less than brick, concrete or fiber cement. Corrugated steel gives you flexibility in terms of color choice. You have the choice of retaining its original color or you can paint it a color of your preference. You'll be able to achieve whatever color scheme you desire for your house. For green benefits, steel is recyclable. You can use it confidently knowing that even if you desire a change in the future, the material will not go to waste.
Steel is a heavy material. This makes it difficult to work with. It may also slow down the pace of work. More labor is entailed when installing steel siding because of its heavy weight. This pushes construction costs up. Unfortunately, steel doesn't provide much insulation for your home. It has low insulation properties, which is associated with higher energy bills.
Much energy is required to manufacture steel. This high energy utilization is a deterrent to eco-friendly practices. Although it is recyclable, steel, like other metals is a non-renewable resource. As it continues to be consumed from the earth, no renewing process is available. This puts it in danger of being depleted. Most corrugated steel siding has to be coated with zinc or other material. This protects it against rust and corrosion. With time, the coatings tend to wear off and must be re-coated or repainted. This adds to your home maintenance expenses. If left unattended, your home can look very ugly.
 forum activity
