Pros and Cons of Crystalline Waterproofing Material
Crystalline waterproofing material is basically a substance that is applied to concrete walls. Whenever it is applied, it will penetrate the concrete and then change it to the point where it becomes a water barrier that is impenetrable. There are several pros and cons that you should consider before using this substance.
Pros
This material will allow you to protect your walls from leaks. Often, it is used on basement walls, where there is a lot of water seepage problems. It is also something that can be added on brand new concrete. Crystalline waterproofing material can also be added to adhere new and old concrete together.
Cons
Installation is something that can be a bit of a hassle. You are going to have to add water to the mixture often so that it will not dry out. You will find that it will heat up as it is mixed with water, this is normal but can be distracting and may slow you down.
Overview
Basically, crystalline waterproofing material has the ability to prevent any leakage from your concrete walls but it can be a hassle to install. However, once you have installed it, you will find that it was well worth the trouble.
Pros
Cons
Overview
