Login Error
Close
Pros and Cons of Limestone Flooring
by DoItYourself Staff
Installing limestone flooring in your home could be something to consider. Here are a few of the pros and cons associated with using limestone flooring.
Pros: Cost and Looks
The cost of limestone flooring is going to be less expensive than many other natural stone options that you have. While it will be more expensive than a ceramic or porcelain tile, it is going to be less than purchasing granite or marble for your floor. This allows you to get a natural stone floor for less money than you would pay otherwise.
Limestone can provide you with a very beautiful look that is applicable in a number of different situations. Limestone has been used as flooring for centuries and can provide you with a very rustic and old world look.
Cons: Sealing and Durability
Limestone is a natural substance and therefore is very porous. If you are going to use it as a flooring option, you will have to seal it periodically for best results. Otherwise, it could stain and look bad within a short period of time.
Compared to other natural stones, limestone is one of the softer products available on the market. This means, that you should avoid putting it in high-traffic areas as it could chip or break.
 forum activity
