Login Error
Close
Pros and Cons of Polycarbonate Panels
by DoItYourself Staff
Polycarbonate panels are extensively used in a variety of applications. Polycarbonate is a thermoplastic that is exceedingly tough, resistant to ultraviolet rays and provides an attractive look. It is available in clear and opaque forms, making it the ideal choice for construction and security-related purposes. Some of the main pros and cons of polycarbonate panels are listed below.
Advantages of Polycarbonate Panels
Polycarbonate panels are finding use in an increasing number of scenarios. Their toughness, durability and lightness are some of the main advantages.
  • Polycarbonate panels are virtually unbreakable and can withstand massive force. For this reason, they are used in the construction of bulletproof windows and police shields. They also find use in the construction of banks, offices and fences.
  • Ultraviolet blockage is another great plus with polycarbonate panels. This quality makes these panels the material of choice for constructing overhead covers and awnings in commercial establishments.
  • Polycarbonate panels are very light when compared to glass, acrylic or other plastics. This results in easy transportation, installation and lower labor costs.
  • Another favorable factor with polycarbonate panels is their high resistance to heat and cold. These panels are ideal for use in any kind of harsh environment, where they can last longer than other standard construction materials.
  • Polycarbonate panels are available in clear glass-like shades and also opaque shades for better cover. Depending on the needs of an organization or individual, these panels can be colored or left translucent, adding to the flexibility of use.
  • The excellent optical properties of polycarbonate panels enable keeping out ultraviolet rays while letting in adequate sunlight and heat. These panels are therefore the preferred material of choice for constructing greenhouses and plant nurseries.
  • Polycarbonate factors are resistant to sunlight, rain and snow. This enables these panels to last in the outdoors for many years without showing signs of fading, yellowing or discoloration.
Disadvantages of Polycarbonate Panels
Polycarbonate panels have few disadvantages when compared to other elements such as glass or plastic. Listed below are a few of the cons.
  • High price is one of the major disadvantages of polycarbonate panels. It is much more expensive than glass and other plastics. As a result, many consumers consider opting for ABS (Acrylonitrile Butadiene Styrene), which is also considerably tough, but has lower impact resistance and heat resistance. ABS is much lower in price and can offer a good solution for buyers who do not require the extreme toughness and heat resistance of polycarbonate panels.
  • Polycarbonate panels are not very resistant to scratching, marring and abrasive surfaces. As a result, denting is possible on the surface if care is not taken.
  • Polycarbonate panels are highly sensitive to abrasive cleaners, alkaline cleaning products and solvents. Therefore, you must be very careful to avoid substances containing acetone, benzene or any other such organic solvents.
  • The manufacturing process for polycarbonate panels is not very environmentally friendly, requires very high processing temperatures and is also very expensive. Also, it requires phosgene, which is known for its ill effects on human health and chlorine, which is also environmentally unfriendly. As a result, several precautions must be taken to protect workers during the manufacturing process.
 forum activity
