Login Error
Close
Pros and Cons of Radiant Basement Floor Heating
by DoItYourself Staff
If you are considering a radiant system for basement floor heating, it will be wise for you to consider the pros and cons of the various types of radiant heating systems before you make your selection. There are basically three types of radiant floor heating systems available to choose from: forced air, electric, and liquid based. A better understanding of the advantages and disadvantages of these heating systems will likely influence your choice these systems.
Ductless Heating
Radiant heat is more efficient because it is ductless. Heat transferred through ducts is more likely to best lost than through radiation.
Health
If you or someone in your family suffers from allergies or asthma from dry air that is more likely to contain dust particles blown throughout your home with forced air system, a radiant system would be a healthier option.
Economic Advantages
Radiant systems reduce electric or gas costs because they are more efficient.
Heat Distribution
In a radiant heating system, heat distribution is more even. Therefore, corners and remote areas of your room, are more likely to receive an even amount of heat.
Installation Costs
Radiant heating systems are more costly to install.
Ease of Installation
Radiant heat Systems  are more difficult to install.
Floor Surfaces
Radiant heat works better with hard flooring surfaces but not so well with carpeting.
 forum activity
