Login Error
Close
Pros and Cons of Using a Carbon Water Filter
by DoItYourself Staff
A carbon water filter is an excellent way of protecting your family from the dangers of toxin-filled drinking water. If you invest in a carbon water filtering system you are sure to safeguard your health while keeping expenses to a minimum, given that installing such a system does not require any large amount of money. Naturally, while the advantages of a carbon water filter are many, it also has a couple of disadvantages.
Advantages Of Using A Carbon Water Filter
Carbon water filters should be the first choice for households that use water which is treated municipally. This is because it is renowned for being most suited to remove traces of chlorine, which would otherwise result in an unpleasant taste.
This water filtering system does not require electricity to work. This is because it depends solely on your pipes’ pressure, and therefore it classifies as a passive sort of filter. Naturally, this is a great economic advantage, since to run a water filtering system using electricity would involve considerable expenses.
A very important trait of carbon water filters is that, while they remove the dangerous contents residing in your water, they do not get rid of the healthy nutrients in the process.
If you opt for this kind of water filter, you do not have to worry so much about maintenance issues. In fact, carbon water filters require a very small amount of maintenance, most of which is routine. Generally, you would have to replace the filter element every three months or so, but that’s about it.
An element of customization is possible when using carbon water filters. This is because you can choose a filter which deals with specifically with the unsafe substances you are most worried about. There is a large range of filters to choose from, so you can find the one that is most suitable for you.
Carbon water filters are also compatible with other kinds of water filtering solutions, and they can be used in conjunction with them to maximize results. For instance, they can be used to complement a reverse osmosis system as a pre-filter. In this case, it would manage to keep the reverse osmosis pores from getting blocked too quickly, since it would remove the larger pollutants before they reach the pores. Moreover, carbon water filters can also be added to distillers to remove any traces of volatile chemicals.
Disadvantages Of Using A Carbon Water Filter
If the filter is not used for a long period of time, it may become full of bacteria. While this bacteria would not be dangerous, it is still an undesirable situation. This disadvantage may however be counteracted by flushing the filter for half a minute a day.
Certain pollutants will not be removed when using a carbon water filter. These pollutants include toxic minerals, fluorides, nitrates and a range of microorganisms.
It is clearly evident that the advantages of using a carbon water filter far outweigh the disadvantages. As such, installing such a filtering system is highly recommended if you want to protect your family from any unpleasant contaminants in your water, while keeping expenses to a minimum.
 forum activity
