Pros and Cons of Using a Damp Basement Sealant
If you have a damp basement, you might want to consider purchasing a damp basement sealant. When you use this type of product, there are several advantages and disadvantages that you will have to consider. Here are a few of the pros and cons of using a damp basement sealant.
Advantages
One of the big advantages of this type of product is that you are going to be able to keep moisture out of your basement. If you have a concrete foundation, there is a good chance that moisture can come through it from the outside. This condensation can come through the wall and lead to a lot of problems for you as a homeowner. If water is allowed to get through the concrete, it could potentially lead to mold problems. Mold can completely devastate a house if it is allowed to grow unchecked. In a basement, it has ideal conditions for growth. It is in the dark and it will have ample moisture to work with.
Stopping the moisture will also allow you to prevent any damage to the wood structure in your house. If the water is allowed to get into the wood, it can lead to rot which could potentially destroy your house.
Another advantage of using this type of product is that it is typically easy to apply. You will be able to roll it on with a paint roller in most cases. This means that it will be very similar to painting the wall or the floor. Most people can apply this type of product without having to hire a professional to do it for them.
Drawbacks
One of the biggest disadvantages of using a damp basement sealant is that it is going to be expensive. These sealants typically come in large buckets and you are going to be making a fairly large investment when you buy them. If you have a large basement, you could easily spend hundreds of dollars on this type of damp basement sealant.
Another disadvantage of using this type of product is that it may not actually solve your problem. Some of these products are not worth the price that is charged for them. If you were to choose the wrong product, you would potentially be spending a lot of money for nothing. You would then still have the damp basement problem and you would have to find another solution.
Another problem with this type of product is that it is going to have dangerous fumes. When you are working in a basement, there is not going to be a lot of ventilation usually. This means that you have to be very careful when you are applying the sealant because it could be dangerous to you. Make sure that you get plenty of fresh air while you are working or you wear a respirator so that you do not have to breathe in the fumes.
