Putting In A Garden Trellis
what you'll need
- Mallet
- Stakes for fence posts
- Wire ties
- Four stakes
- Drill or masonry nails
- Hammer or screwdriver
Installing a garden trellis is not difficult and requires no special tools or knowledge. Here are steps for installing three kinds of trellises: A fence trellis, a vine trellis and a wall trellis.
Putting in a Trellis Fence
Step 1 – Placing the Posts
Mark out the exact location where you plan to place the trellis fence.
If you are using trellis panels, pound the fence posts into the ground at intervals equal to the length of each panel. If you are using a concertina trellis, place the fence posts every 3 feet.
Step 2 –Secure the Trellis to the Posts
Use the wire ties to secure the trellis to the posts. You can nail the panels to the posts to give it a more permanent structure. With the concertina trellis you can adjust the height of the fence quite considerably but nailing it to the posts would not be recommended.
Step 4 – Allow for a Gate
Leave one panel so that it is removable to act as a gate if necessary. Leave one end of the concertina trellis loose for the same reason. Although not as robust as a normal fence, a trellis fence is very serviceable and can divide a garden very effectively.
Putting in a Vine Trellis
Step 1 – Prepare the Area
Clear the area where the vine trellis is to be installed. If the vine already exists it must be carefully moved away from the area in which you will be working.
Step 2 – Position the Trellis
Examine the vine trellis and check that it has no broken parts. If this is a typical arched vine trellis, put it in the position that you intend to install it and mark where the base is.
Step 3 – Secure the Trellis
Using the base markers, pound the four stakes into the ground. Position the vine trellis against the stakes and use the wire ties to secure the trellis in position. The wire ties can be replaced by something stronger when the trellis has settled after a few days.
Step 4 -Draping the Vine
Once the trellis is safely secured you can carefully rearrange the vine so that it drapes over the arch trellis. If the vine can be brought up both sides of the arch, you will have more stability. If the vine is new, it can be threaded through the trellis and then allowed to establish its own path.
Putting in a Wall Trellis
Step 1 – Position the Trellis
Determine the position on the wall where you want to fix the trellis. Hold the trellis against the wall and mark where the fixing rings are.
Step 2 – Insert the Masonry Nails
If the wall will accept them, hammer masonry nails into the positions you have marked. The nails should be 2 inches long. Hammer them just far enough to leave ½ inch protruding from the wall. Note: Remember that masonry nails are driven better with a tapping technique. Hitting them hard can be painful if you are holding them in your fingers.
If the wall will not take masonry nails drill holes where the rings are marked and use wall plugs and screws to fit the trellis.
Hang the wall trellis from the nails or use the screws. Installing garden trellis makes such a difference for so little effort.
