Radiant Barrier Roof Decking vs Radiant Barrier Foil
When you are comparing radiant barrier roof decking to radiant barrier foil, there are a few things to keep in mind. Make sure that you understand both the pros and the cons with these so that you will be able to make an educated decision about which one will work best for you. Each material has a benefit in certain applications.
What you need to keep in mind with your radiant barrier roof decking is that it is not going to be able to benefit you during the winter. If you have your radiant barrier roof decking sandwiched between other materials, you cannot expect it to be able to do you any good at all. In order for it to be able to be effective, it is going to have an airspace that it can face. In areas with very harsh changing climates, you may want to find another material.
When dealing with a radiant barrier foil, you will use this by stapling it to the underside of your roof rafters. This means that if you want it to work, you have to have it sandwiched in between materials. This is easier to install, and works in moderate climates.
