Login Error
Close
Radiant Garage Heater Smackdown: Kerosene vs. Propane
by DoItYourself Staff
A radiant garage heater is a heat souce designed specifically to heat your garage and uses kerosene or propane to give it power.
The differences between propane radiant garage heaters and kerosene radiant garage heaters are:
Kerosene uses flammable hydrocarbon oil used as fuel in a radiant garage heater
Propane in a radiant garage heater uses a colorless gas that is found in petroleum and natural gas and use it as a fuel
Propane Radiant Garage Heater Benefits
A radiant garage heater is essential during those long winter months when you have to get up early in the blistering cold and you don't want to wait 20 minutes for your car to warm up. Using propane for your radiant garage heater is great, because propane is a highly concentrated source that can hold around 1,000 gallons of fuel. Propane is environmentally friendly because it does not contain lead, has low sulphur content, creates lower greenhouse gas emissions, and produces harmless carbon dioxide.
Kerosene Radiant Garage Heater Benefits
Using a radiant garage heater can be beneficial to your garage, because it can protect your storage by preventing it from getting ruined during the winter. The use of kerosene in your radiant garage heater is great because they do not use any electricity, and the kerosene can be stored in large quantities. A kerosene radiant garage heater is safe, reliable and burns efficiently and cleanly.
 forum activity
