Login Error
Close
Raised Paver Patio Designs
by DoItYourself Staff
To get the best out of your brick patio, it is a good idea to have some paver patio designs in mind before you start buying the bricks. Paver patio designs are available in a variety of styles and sizes, so there should be at least one which will perfectly fit the area you wish to install your design upon. The best kind of layout will help to accentuate the house, and compliment important features such as bay windows, or cornices. The raised paver design will help you to work out exactly what you need to complete your task, and can be really important in making the best from your patio.
Purpose
Consider the purpose of the paver patio. Is it intended to be an access route from French doors to the beginning of the lawn, for example, or will it be used for other elements, such as a seating area and a barbecue? These questions are important to the design, as the purpose of the final patio can influence the patterns, colors, and situation of the patio. Other questions to be considered are the amount of use the patio will have, as this can influence the type of brick being used. A larger patio may be used for social gatherings, so bear this in mind when designing your paver layout.
Patio Style
Compare the brick paver with other parts of the garden, for example a driveway, or a path leading up to the house. The pattern of the paver should match these as closely as possible. The shape of the house should also influence the pattern, as a round paver design will jar against a pavement which has rather square outlines and sharp corners. If the garden where the patio will sit has a number of round flowerbeds, then you can consider matching the patio up with these shapes, although it will dectract from the connections between house and pavers.
Measurements
Take careful measurements of the area you intend to cover with the pavers. Measure all the lengths, including the height at which you intend your paver to be placed, and the stairs leading to and from the patio. You will also have to measure around plumbing features such as garden taps, window boxes, and other areas which will need to be included in the design. Pay attention to the orientation of the design, as you don't want a patio which is hidden from the sun, or one which is only in the light at midday. You should use these measurements when calculating how you will install the patio, for example you will need around 12 feet for tables and chairs, and 15 square feet to provide easy access to these. Other estimates suggest that no less than 20 feet will be enough to make the user feel comfortable.
Draw a Design
Once you have these measurements and plans, you can begin to draw out your design. This is best done using architects paper, or graph paper which will best help you to co-ordinate the design and allow it to be properly put down on paper, to scale.
 forum activity
