Login Error
Close
Real vs. Faux Brick Siding: Pros and Cons
by DoItYourself Staff
Faux brick siding is relatively common in many newer homes. It is to be compared with real brick siding, often called face brick. There are a number of differences between these two types of brick walls, although appearances can be deceiving. Both of these walls generally look very similar from the outside. Before you install one or the other of these types of brick siding, however, it's important to consider the pros and cons of both. This will help to ensure that you don't spend more money than is necessary and that you end up with the type of brick fixture in your home that will be both attractive and durable.
Pros and Cons of Real Brick Siding
Real brick siding is durable and strong. It is often used as a structural element of homes. This means that it can be installed in a wide variety of locations throughout your house, and it is likely to be long lasting and sturdy. Among the other benefits of a real brick siding installation are the fact that this type of brick is more resistant to weather and other types of exposure damage, and also that it generally requires less maintenance than other types of brick siding.
However, there are some drawbacks to real brick siding as well. Chiefly among those is the fact that, because real brick siding makes use of more materials than faux brick siding, it costs significantly more to install. This is due both to the fact that there are more materials and also because it will require additional time in order to install real brick siding. Additionally, real brick siding is heavier and is oftentimes more difficult to install than faux brick siding.
Pros and Cons of Faux Brick Siding
While it doesn't have the structural support of real brick siding, faux brick siding is much lighter and easier to install. It requires less material, generally consisting only of one row of bricks maintaining a wall, or even of simple brick faces attached to a preexisting wall. This means that the costs in terms of materials and labor will be much lower when you plan to install faux brick siding as compared with real brick siding.
However, because faux brick siding is lighter than real brick siding, it is also more subject to damage for a variety of reasons. Over the lifetime of the brick, you may expect to have to work harder to maintain the faux brick siding than you would a similar real brick wall. Additionally, because it cannot be used for structural support, there may be some limitations as to where you can install faux brick siding in your home.
Whether faux or real brick siding is best for your home is a question that you should discuss with a contractor or with another professional. Weigh out factors like your budget, the layout of your home, and the amount of time and effort you're willing to dedicate to maintenance when you consider which to choose.
 forum activity
