Login Error
Close
Recessed Oval Medicine Cabinet Installation Tips
by DoItYourself Staff
A recessed oval medicine cabinet can give a modern appeal to your bathroom. Keep your counters clear of clutter but still have what you need at hand. You can install one in your existing wall by following the tips below.
Position the Cabinet
The normal height is 72” from the floor to the top of the cabinet. Be sure to make adjustments if the user is significantly shorter or taller than average.
Beware of What’s Behind the Wall
Find the studs in the wall using a stud finder. Carefully cut a small opening on the sides of the stud to check for plumbing or electrical wires. If there are obstructions they have to be moved, usually by a licensed plumber or electrician.
Cut Out the Opening
Once you know you have a clear wall trace the outline of the back of the cabinet on the wall and cut out the opening with a saw. Then trim back the stud as needed to fit the cabinet in the opening.  Another kind of recessed cabinet is meant to be installed between the studs.
Final Adjustments
Be sure to level the cabinet before screwing it into place. Attach the door (most hinge of either side) and be sure it opens and closes freely. Now you can screw it into place.
Now you can fill the cabinet with your essentials and nobody will suspect what you have behind the mirror.
 forum activity
