Login Error
Close
Red, Black, White, Blue: What Each Ceiling Fan Wire Means
by DoItYourself Staff
Every single ceiling fan wire has a special purpose in order for the fan to function correctly and safely. Although there are four different wires involved, wiring a ceiling fan is not a difficult job. Hence, here is a  brief description of every wire which might be helpful when installing a ceiling fan. However, as with any other electrical device, remember to switch off the current from the main box before you start installing a ceiling fan.
Wiring Color Codes
Before reading this information, it is important to notice that there are different wiring color codes in different countries around the world. Hence, the wiring color codes in Europe are not the same as those in North America. Thus, before trying to install a ceiling fan, make sure to use the correct wiring diagram to connect the fan. Here we will follow the wire colors according to the wiring color codes for USA and Canada.
Red Wire
A ceiling fan usually consists of two main parts: the fan and a lighting assembly. Thus, the red or striped wire is the hot wire for the lighting fixture of the ceiling fan. If your ceiling fan does not have a lighting fixture, it will only have the three other wires. Moreover, sometimes this wire can come directly from the main circuit breaker in order to always be on.
Black Wire
The black wire is the main hot wire, which generally comes from the main circuit breaker. This wire is always on, so make sure that there is no current when dealing with this one to avoid any unwanted circumstances. For this reason, the main function of the black wire is to provide current to the fan’s motor.
White Wire
As with any other electrical fixture, the white wire of the ceiling fan is the main neutral. This wire is the neutral of both the light fixture and the fan motor. Hence, this white wire should be attached to the other neutral wire of the house wiring. However, the white wire of the house wiring system could also have a piece of tape attached to it, meaning that the wire is probably being used for another purpose.
Blue Wire
Since there are a lot of color codes, it is not possible to state the exact purpose of this wire. To check the main purpose of the blue wire, you can examine the wiring diagram of the fan. However, another important wire is generally a green one, which is used to earth all the system of the ceiling fan.
When dealing with a ceiling fan wiring system, it is important to know what you are doing and to work as safely as possible, so even if the current is switched off from the main supply, it is also recommended to double check for any current flow by using a tester. Otherwise, if you are trying to repair a ceiling fan, but you cannot understand its wiring connection, it is strongly recommended to refer to a professional electrician.
 forum activity
