Login Error
Close
Refinishing a Textured Ceiling
by DoItYourself Staff
what you'll need
  • Scraper
  • Screwdriver Head
  • Sandpaper
  • Paint
  • Paintbrush
  • Varnish
  • Step Ladder
  • Paper Towels
When refinishing a textured ceiling there are some things that should be done. Here are some tips on doing this job:
Step One - Taking Off The Old Finish
Remove the finish that was already on by rubbing a scraper across the surface of the ceiling. A flat head screwdriver could also be used to get the job done. If a scraper or screwdriver are not available, use sandpaper to remove the old finish. Use a paper towel to wipe the ceiling clean after removing the finish.
Step Two - Putting On The New Paint
By using the paintbrush, new paint can be layered over the textured parts of the ceiling.
Step Three - Putting The Varnish On
When the new paint job is finished a layer of varnish will be added over the paint. Use a new paint brush when adding the varnish. By using a new paintbrush the varnish will not cling to dirt. Cover the edges of the ceiling until completion. After this the varnish is left to dry.
Step Four - The Final Finish
Rub some paper towels over the surface of the varnish so the shining areas will be removed by the paper towels. The refinishing job is now complete.
 forum activity
