Refurbishing Brass Door Handles to a Fine Shine
what you'll need
- Masking tape
- Philips screwdriver
- Rubber gloves
- Ammonia
- Brass cleaner
- Soft Cloth
- Clear lacquer finish
Usually, when brass door handles are refurbished all of the brass hardware is included in the cleaning process. It should be refurbished periodically.
Step 1 – Place Masking Tape
Put masking tape around door hinges on both sides.
Step 2 – Take Off Other Hardware
Take the knob off by unscrewing two screws and glide doorknob away from housing.
Step 3 – Use Rubber Gloves
Put rubber gloves on to protect hands from chemicals.
Step 4 – Judging the Tarnish
Scrutinize the extent of the tarnish. Remove excessive tarnish with undiluted ammonia by soaking the brass door handle for an hour. If the tarnish isn’t excessive skip step 4.
Step 5 – Clean With Brass Cleaner
Put small amount of brass cleaner on cloth. Rub the brass door handle with several applications. Also clean hinges with brass cleaner.
Step 6 – Apply Lacquer Spray
Spray the door handle with clear lacquer. This coating protects the doorknob. This lessens the frequency of cleaning.
Step 7 – Put Door Handle On
Screw door handle back on. Take tape away from the edge of the hinges.
