Login Error
Close
Relaxation Techniques to Practice at Work
by DoItYourself Staff
When you are at work, relaxation techniques can make a big difference in your level of stress and comfort. If you practice these techniques while working, they can improve your day and make you feel much better. Here are a few of the best relaxation techniques that you can practice while at work.
Deep Breathing
One of the best techniques that can help you relax almost instantly is deep breathing. The pace at which you are breathing helps control how quickly your mind is working. If you take long, slow deep breaths, your mind will slow down and everything will seem less stressful. In order to do this, you need to sit upright with your back straight in a chair or stand up. Then start taking very deep breaths through your nose and expand your stomach. Then when you exhale, breathe out through your mouth. When this happens, your stomach should go back in. Continue doing this for a few minutes and you will undoubtedly notice a difference in the way you feel.
Muscle Relaxation
Another technique that you can use while working is progressive muscle relaxation. This is a technique that will help you relax your muscles one at a time. In order to do this, you will focus on one muscle at a time. You will tighten that muscle for approximately 10 seconds. Then you will allow it to relax. Start out on your right foot and then move to the left foot. Then move to the right calf and then the left. Keep moving up your body in this manner and tightening and then releasing each muscle. After you are done, your entire body should feel very relaxed compared to what it was before. You can do this while you are sitting your desk or standing up taking a break.
Self Massage
You can also try to practice self massage when you have a moment to do so. By rubbing certain parts of your body, you can relax the muscles and help yourself eliminate a great deal of distress that you normally have. For example, one of the most effective ways to massage yourself is to massage the scalp. In order to do this, you can spread your fingers over your scalp and put your thumbs behind your ears. Then move your scalp around by moving your fingers in tiny circles. Do this for about 30 seconds and you will generally feel a lot better.
You can also do a nice massage to release sinus pressure and induce relaxation. For this one, you need to put your fingers on the bridge of your nose. Then move in a downward motion and out across your cheek bones directly below the eyes. This will allow you to massage your sinus cavity and you will most likely feel better after a few repetitions. Do this for 10 or 15 cycles and then relax.
 forum activity
