Login Error
Close
Remodeling a Basement without Windows: 4 Decorating Ideas
by DoItYourself Staff
Remodeling a basement may sound like a daunting task, but there are a number of ways that you can make a basement look decorative and comfortable to live in. With simple modifications, you can turn a dark and drab basement into a room where you will feel at ease and comfortable in. Follow these simple and easy tips.
1. Install New Wiring and Light Fixtures
Your basement will most likely have a lot of wiring and pipes installed. You can choose to cover these if they look unattractive. You can also opt to install a whole new set of wiring. This will apply especially to basements that do not have windows as you will need light fixtures to illuminate the room during the evening. Customize the light fixtures as you see fit, keeping in mind the style of your home. If you choose, you can install a separate circuit breaker or electrical power box that powers the basement alone. This way, you can manage the electricity being used in the main areas of the house, and not confuse them with the energy needed to power your basement room.
2. Add Proper Lighting
You can add much smaller fixtures such as hockey puck lights, track lights, little floor lamps and table lamps so that the basement looks more festive. These little light fixtures will also make the room feel warmer and cozier. They are also useful for when you use the room to study or read. Keep in mind that you should not use fluorescent lights or CFL bulbs as they give off a kind of light that does not suit a basement environment. You basement will feel awkward if the kind of light you provide is the wrong kind. Instead, you can purchase incandescent lights which give off the warm sort of feel to your basement.
3. Paint the Basement
One great way to add life and color into a dark basement is to paint it. Use warm or bright colors that are pleasing to the eye and give a welcoming sort of feeling when you enter the room. You can choose from a wide variety available in stores. Just be sure to pick a color that makes you feel comfortable and at ease.
4. Add Windows
Windows are a great way to let some light into the room. You can install windows to enable the room to breathe. There is a wide variety of windows available. They come different shapes and sizes, and are also available in different price ranges to suit your budget. Windows also serve as great ventilation devices, as an open window will allow fresh air and circulation in the room. In most areas, you will be required to equip your basement with a safety exit window in case of emergencies. If your basement also serves as a living area for a member of your family, consider installing a large window not only for aesthetic reasons, but also as a safety precaution.
 forum activity
