Login Error
Close
Remodeling Mobile Home Interiors: What You Should Know
by DoItYourself Staff
Making the decision to remodel your home is no doubt a big one that you have probably put much thought and money into. However, you should know that remodeling a mobile home is much different than remodeling a regular stick built home. Here are some factors that you should take into consideration before remodeling your mobile home.
Structure
Be sure to consider the structure and level of your mobile home. Check out how it is balanced or standing on the ground. The structure of a mobile home is very different from a conventional home so take this into account as well as the electrical and plumbing structures of your mobile home and you may want to have a professional come in to assist with any restructuring that may affect either of these systems.
Materials
Many materials used for conventional homes are not good materials for mobile homes – for instance you may want to install a tile floor however they may not be right for a mobile home given the materials needed.  Be sure to do your research on what types of materials are used in your home that way you can be sure to use similar materials that are appropriate for your mobile home.
 forum activity
