Login Error
Close
Removable Wallpaper: Pros and Cons
by DoItYourself Staff
Removable wallpaper is quickly becoming a very popular material for many homeowners and renters to use. Here are a few pros and cons associated with removable wallpaper.
Pros
One of the major advantages of this product is that you can install wallpaper and then remove it without damaging the wall. You do not have to use any special adhesives or removers in order to use it. This makes it an ideal solution for renters that want to change the color of their walls without doing any damage to them.
This type of wallpaper is also very convenient and easy to install. It could potentially save you a lot of time when trying to cover up your walls.
Another advantage of removable wallpaper is that it is inexpensive. Most of the time, you can purchase this wallpaper for less than other types of wallpaper.
Cons
Although removable wallpaper can be convenient, it can also cause you some problems as well. The adhesive that is used with this type of wallpaper is designed to detach from the wall when you pull on the wallpaper. Because of this, the wallpaper has been known to come off of the wall when something rubs up against it or pulls on it.
 forum activity
