Login Error
Close
Remove A Hot Tub
by DoItYourself Staff
what you'll need
  • Reciprocating Saw
  • Jigsaw
  • Safety Goggles
  • Safety Mask
  • Work Gloves
  • Protective Clothing
  • Hot Tub Instructions
  • Dumpster
If you do not intend on giving away, reselling or simply moving your hot tub, the best way to go about removing a hot tub is simply to take a sawzall to it. It is safe to say, however, that the process is a little more complicated in nature than simply sawing the spa into bite-sized pieces. Here is a guide to removing a hot tub that you are no longer interested in.
Step 1: Reread Instruction Manual
Re-read the manufacturer's instructions for the hot tub to remind yourself of all of the aspects of the spa's original construction. You need to have a decent idea of what electrical elements are involved, how the heater is hooked up, how the gas lines work and so on. Immersing yourself in these details will make sure that you are safe and protected when you are disassembling your spa for removal from your properly.
Step 2: Unplug Electrical Wiring
Now you are going to want to unplug all of the electrical hook-ups including the gas line, electricity and the heater. Make sure that all of this electrical equipment is properly removed. When you are done, you should only be dealing with the wooden frame of the spa and the actual spa bed, which is likely going to be made from fiberglass, plexiglass or some other type of molded plastic. Removing all of the electrical cords and wiring is vitally important; otherwise you could shock yourself by accidentally cutting into one of these lines with your saw.
Step 3:  Disassemble Spa Skirt
If there are any parts of your hot tub that are connected via screw or nail, you can remove these manually through the use of a screwdriver or hammer. Some Jacuzzi and spa tubs are built with their skirts comprised of wooden slats that are connected via tongue and groove. If this is the case, then you can disassemble the skirt for the hot tub relatively easily without having to saw apart the individual pieces.
Step 4: Disassemble Tub
The more difficult part of the removal process for your Jacuzzi or spa is going to be breaking up the actual hot tub, which is likely one single piece made from plastic or another durable material. The fastest way to deal with this is to don safety gear and simply attack it with a jigsaw or reciprocating saw. The process is relatively messy, as dust will be produced as a result of the sawing. Break the hot tub into pieces that can easily be carried out of the yard and deposited into a dumpster. Make sure that you wear the proper safety gear at all times when cutting up the hot tub material. This should include heavy work gloves, sturdy clothing and safety goggles. You may also want to wear a safety mask.
 forum activity
