Remove Lipstick Stains from Upholstery
what you'll need
- Plastic spoon
- Lighter fluid
- White toothpaste
- Hairspray
- Sponge
- Ammonia
- Isopropyl alcohol
It’s not too difficult to remove lipstick stains from upholstery, although at first it cane seem like a nightmare task.
Step 1 - Toothpaste
Use white toothpaste to remove lipstick stains. Put some on the stain and use a clean cloth to scrub and remove the stains.
Step 2 - Lighter Fluid
If the lipstick is caked on, remove all you can with a plastic spoon. Put lighter fluid on a clean cloth and scrub gently to remove lipstick stains.
Step 3 - Alcohol
Isopropyl alcohol is a good item to use to remove lipstick stains. All you need to do is put some on a clean dry cloth and rub the stain. As the alcohol evaporates quickly you might need to add more of it to the cloth to complete the job.
Step 4 - Ammonia
A solution of equal parts water and ammonia is good to use to remove lipstick stains. Put it on the stain using a sponge and scrub the area lightly. Rinse with a cloth that’s been soaked in cold water.
Step 5 - Hairspray
Spray hairspray on the lipstick stain. Leave it for 5 minutes and the take it off with a dry, clean cloth. The stain will come off with it.
