Login Error
Close
Remove Soap Scum from Your Drain to Prevent Clogs
by DoItYourself Staff
what you'll need
  • Drano (TM) or similar chemical clog reducer
  • Bell plunger
  • Wrenches and screwdrivers
  • Drain snake
  • Bucket
  • New drain stopper
  • New pipes
In homes with older plumbing, trying to remove soap scum to prevent drain clogs can be a battle. Follow these tips to remove soap scum from the drain.
Step 1: Use a Chemical Clog Reducer
Open the drain stopper fully and clear any standing water with a bell plunger. Pour in chemical clog reducer following the instructions. Wait 2-3 hours, and do not put anything down the drain. Run hot then cold water down the drain for 1 minute each to test if the clog is gone.
Step 2: Remove the Drain Stopper and Use a Drain Snake
Detach the drain stopper and insert the drain snake as far down the pipe as you can. Turn its handle, then extract it and rinse it off into a bucket. Test the drain flow again by first running hot, then cold water for 1 minute total.
Step 3: Replace the Drain Stopper
If the soap scum clog recurs soon after clearing, replace the pull-up drain stopper with a simple rubber drain plug on a stainless steel chain.
Step 4: Check and Replace the Pipes
If your house has metal plumbing pipes, upgrade to PVC pipes.
 forum activity
