cancel
Job type :
Zip Code :
community forums
comments
Removing Ceramic Bathroom Tiles
By Murray Anderson
Even though bathroom tiles are meant to be installed permanently, sometimes tiles can get broken or come loose so they need to be removed. Here's how you can get broken or loose ceramic tiles off your bathroom wall. Remember that getting the tile of the wall is just your first step. Once the tile is off, you will likely need to repair the underlying wallboard and remove any remaining before you can install your replacement tile.
Things you’ll need
2-3” stiff bladed putty knife
Grout removal tool
Old flat head screw driver
Hammer
Utility knife
Power drill and carbide-tip drill bits
Masking tape
Rotary tool with grout removal attachment
Dust mask and eye protection
Removing a broken tile.
  • If you have a broken tile you obviously don’t need to worry about saving it. You may be able to pry it off the wall by sliding the putty knife under the tile at a very low angle (almost parallel to the surrounding tiles), then moving the knife around to break the tile away from the glue or mastic holding it on.
  • If that doesn't work, your next step is to remove the grout surrounding the tile and holding it to the adjoining tiles. Use your grout removal tool (a strong metal tool with a triangular shaped cutting blade on the end available at home or tile stores) or the old flat head screwdriver and a hammer to chip out the grout. (See my related article 'Restoring Tile Grout' for more information on how to remove tile grout).
  • Once the grout is out you can break the tile into smaller pieces by putting an X of masking tape across the tile from side to side (this will stop the drill bit from dancing on the tile's hard surface).
  • Now, using a carbide tip drill bit, drill a series of holes along the X then remove the tape. You should be able to pry off the smaller pieces of tile using your putty knife or flat head screwdriver.
Removing a single tile loose tile
  • Depending on how loose the tile is you may be able to remove it by simply sliding your putty knife under the tile and prying up gently.
  • If the tile won't come off you'll need to get rid of the surrounding grout as above.
  • Once you've got the grout out all around the tile, slide the blade of the putty knife under the tile and gently tap the handle while moving the knife all around underneath the tile, prying up a little at the same time. Work slowly so as not to damage the adjoining tiles, since they could easily chip (particularly at the corners).
  • Depending on where your loose tile is located, you may also need to remove any flexible caulking that is holding the tile at the bottom close to the bathtub.
  • Eventually the tile will pop off the wall, undoubtedly bringing some of the paper backing from the underlying drywall with it.
  • Once you have the tile off, you'll need to repair the underlying drywall, let that repair set up and install your new tile.
Removing ceramic tiles requires some muscle and persistence. However, even though tiles are installed permanently, accidents and life happen so it's nice to know you don't have to live with an ugly loose or broken tile or even worse, tear down a whole wall just to repair a single bad one.
Visit our kitchen and bathroom community forum to see how other people are handling ceramic tile removal.
Laying a new ceramic tile floor? Here’s how to grout it.
Murray Anderson is an experienced freelance writer with over 500 articles published on the web as well as in print magazines and newspapers in both the United States and Canada. He writes on a wide range of topics and is a regular contributor to DoItYourself.com.
member comments
Related Articles
Top Ten Benefits of Ceramic Tile
Ten reasons why ceramic tile makes for great floors... read more
Using Ceramic Tile in Your Home
This article provides ideas about all the different ways you can use ceramic tile to... read more
Ceramic Tile Shower 3 - PreparationCeramic Tile Shower 3 - Preparation
This section prepares you for installation of ceramic tiles in the bathroom. It includes tools... read more
articles we like
Stained Glass Windows
Stained glass windows add a colorful, distinctive accent to a home while protecting privacy... read more
Solid Surface Countertops
Solid surface countertops are made from surfaces manufactured with a blend of resins and mineral... read more
Is Growth Hormone the Fountain of Youth?Is Growth Hormone the Fountain of Youth?
The following article discusses how taking growth hormones may help slow the aging process... read more
sponsored articles of the day
diy centers
