Login Error
Close
Removing a Sink to Lay Bathroom Floor Tiles
by DoItYourself Staff
what you'll need
  • Screwdriver
  • Wrench set
  • Pail
  • Knife
Laying new bathroom floor tiles is quite an ordeal, since appliances and units get in your way. Some people prefer to lay the new tiles around the appliances without removing them, since it takes less effort to do so. However, it is recommended that when you lay new tiles you remove any bathroom appliances and lay the tiles on a clear surface. While it sounds complicated and tiresome, it is really not such a big deal, and it guarantees a much neater result than merely going around your sink.
Step 1 – Unseal the Sink From the Wall
The sink is connected to the wall by a line of caulk, so you will need a knife to cut through it and unseal the sink. Usually, this line keeps going down along the wall and underneath the sink. Take care not to hurt yourself or scratch any surfaces.
Step 2 – Turn off the Valves
Once your sink is unsealed, make sure you turn off all your water valves, which are generally located at the back of the pedestal, close to the floor. When the valves are turned off, get rid of any residual water by opening the faucet to drain it.
Step 3 – Detach the Drainpipe
Find the place where the drain joins underneath the sink and proceed with removing it using a wrench. Then detach the drainpipe at the point where it enters the main floor drain.
Step 4 – Unbolt the Pedestal
Unscrew the bolts connecting the wall and the sink so that you may remove the pedestal. An extra pair of hands would be useful at this stage, since it may be difficult to manage everything on your own.
Step 5 – Remove the Sink
Carefully lift the sink up, making sure you do not hit it to avoid any damage. Then set it aside in a safe place where it is not in the way. Again, it would be best to have someone else to help you, especially if the sink is heavy.
Step 6 – Remove the Pedestal
Lastly, remove the bolts securing the pedestal to the floor, so that you may detach the pedestal from its place. In case of a vanity, you will probably find two or more screws which secure it to the studs on the wall behind it. In this case, unscrew them all and proceed to removing the vanity.
Once you are done, you can lay the new tiles without any problem. Merely laying the tiles around the sink definitely sounds simpler, but it also tends to backfire in terms of neatness. Thus, in the long run it is always best to take the seemingly more complicated route when you decide to lay new bathroom tiles. As seen through these steps, however, it is really not such an arduous task to remove your sink before laying new tiles. Following this simple guide will help you get the job done easily and in a short time.
 forum activity
