Login Error
Close
Removing Crayon Stains from Wood
by DoItYourself Staff
what you'll need
  • Washcloth
  • Sponge
  • Starch
  • Paintbrush
  • Scrub brush
  • Mini vac
  • Feather duster
  • Bucket
  • Stirring tool
  • Broom and dustpan
  • Paper towels
If any of your home's wooden furniture or flooring has recently fallen victim to crayon stains, you may be curious about how to properly get rid of them. Fortunately, crayon stains can be removed from wood with the aid of several common household items in just a few simple steps.
Step 1 - Give the Affected Area a Preliminary Dusting
You'll need to remove any light dirt and dust from your furniture or flooring before proceeding to purge the crayon stains. Start by going over the stained areas with a feather duster or mini vac, then use a lightly dampened sponge, washcloth or paper towel to gently blot up any remaining dust or caked-on debris. This preparatory dusting will ultimately make the stain removal process easier, so take care to be thorough when carrying out this step. Once the affected wood has been properly dusted, you'll be ready to proceed with the next step.
Step 2 - Apply Your Stain-Removal Solution
Now that your wooden furniture or flooring is completely dust-free, it's time to produce a simple, though highly effective, homemade stain remover. To produce this solution, combine starch and water inside of a small bucket, then proceed to stir the ingredients until a thick, paste-like substance has taken shape. Having produced your stain remover, use an expendable sponge or washcloth to apply it to your wood-based crayon stains. If you want to be extra-meticulous, this solution can also be applied with a small paintbrush.
Once your homemade stain remover has been successfully applied, allow it to sit for 1 to 3 hours in order to ensure that it has ample time to fully harden. This will help the newly formed solution lift and remove the stains.
Step 3 - Remove Your Cleaning Solution
Having confirmed that your stain remover is sufficiently hardened, you're ready to remove the solution, crayon stains in tow. With the aid of a dampened washcloth or sponge, proceed to scrub the solution-laden areas using broad circular motions. Depending on the brand of starch you used to produce your stain remover, removing it may require a fair amount of elbow grease.
Once the stain removal solution has been completely removed, use a mini vac or a broom and dustpan to get rid of the broken-up pieces of hardened stain remover. Follow up by using a dampened sponge, washcloth or paper towel to soak up any dust produced by the cleaning solution. If the crayon stains have not been completely removed, repeat steps 2 and 3 until seeing the desired results. Keep in mind that stains that have been given a lot of time to set in may require more stain-remover applications than recently discovered stains.
The next time one of your children colors on any of your home's wooden fixtures, just remember these 3 helpful steps and the cleaning process will be a breeze.
 forum activity
