Removing Oil-Based Stains from Wood Ceiling Beams
what you'll need
- Mild detergent
- Paper towels
- Mineral spirits
- Vinegar
- Baking soda
- Newspapers
- Cloth
- Water
- Spray bottle
- Mask
- Eye goggles
- Protective gloves
- Ladder
- Sponge
Removing oil based stains from wood ceiling beams is not an easy task, unless you work on the stain right away. If the oil has been there for quite some time, it will take some more work. When removing stains, it is always important to consider the finishing coat of the beam before choosing which method to employ. Hence, it is always best to start with the safest methods first. Below are different ways to remove oil based stains and how to do them step-by-step.
Step 1 – Blot the Oil
When the oil is still fresh on the ceiling beams, get some paper towels and access the ceiling with a table, a chair or a ladder. Stick the paper towel directly onto the affected area. The oil will definitely be sucked out by the towel due to gravity. If the paper towel is not placed there in time, the oil will seep through the pores in the wood and make the stain look worse.
Step 2 – Use Mild Detergent
While the oil is blotted from the ceiling, prepare some soapy water solution by adding a bit of mild detergent in a cup of water. Stir the detergent well until it is melted completely. Soak a piece of cloth or sponge in the soapy water solution and squeeze out some excess water. Remove the paper towel from the affected area and wipe it carefully with the damp cloth or sponge. Rub the affected area thoroughly until the oil is dissolved. Wipe the area with a clean dry cloth afterwards. If some of the oil is still clinging to the beam, repeat the process.
Step 3 – Use Vinegar
If the stain is a few hours or a few days old, mix 1 part of vinegar with 1 part water in a spray bottle. Spray the affected area with the solution and leave it for five minutes. Wipe the area with a clean dry cloth afterwards. Repeat the process until the oil stain has been removed completely.
Alternatively, you can also make a paste out of baking soda and vinegar. Make a poultice out of the 2 ingredients and rub it thoroughly onto the stained surface. Leave it for 10 minutes before wiping it with a piece of dry cloth. Repeat the process. To remove the residue, spray the area with pure clean water and wipe it off with a dry cloth afterwards.
Step 4 – Use Mineral Spirits
Wear some gloves, mask and eye goggles when using this method. Use this only when the above safer methods do not work. Dampen a piece of rag with the solvent and use it to wipe the stained area clean. Continue rubbing the stained area with the rag soaked in the solvent until the oil stain is no more. Clean the area after with cloth soaked in soapy water. Wipe the area dry with a piece of clean dry cloth.
