Login Error
Close
Removing Window Film Effectively
by DoItYourself Staff
what you'll need
  • Steamer
  • Vinegar or ammonia based cleaner
  • Razor blades
  • Spray bottle
  • Hand held blow dryer
  • Plastic wrap
  • Paper towels
Window film is a great sunblock, but on a home or vehicle, it may often become affected, scratched or damaged enough to require replacement. Whether it's in a vehicle or a building, the steps to removing safety tint or film are the same. Ammonia fumes can damage sensitive electronic parts, fabric and adhesives in a vehicle, as well as be hazardous to breathe, so don't use ammonia fumes in an enclosed vehicle (like back window tinting).  Use a blow dryer and razor instead.
Step 1-Dissolve The Adhesive
Both ammonia and vinegar will dissolve tinted film adhesive, although it may take several hours to do so. Use a spray bottle filled with soapy ammonia and spray down the film thoroughly. Allow it to sit and respray as it dries. To speed up the process, apply a film of plastic wrap over the sprayed window to hold in the moisture. Leave overnight for best results. Have ample ventilation if using ammonia in an enclosed area, as it can be hazardous to breathe in.
Step 2-Loosen The Film
One alternative to chemicals, particularly in a vehicle where ammonia and vinegar fumes may affect the adhesives in other car components, is a hand steamer. When combined with a blow dryer and steamer, the combination of wet and then dry heat is very effective at getting your tint to release. Try to remove the film during the day or with the window in the sun. The warmer the window glass is, the easier the tint will peel.
Step 3-Peel The Film
Once you have softened the window film with ammonia and your blow dryer, use a razor to grasp one corner or edge of the film and pull. Depending on how much adhesive you've been able to dissolve, the tint will either release and come off in big sheets or pieces, or it will stubbornly resist and come off in small pieces. Give it more time, ammonia and heat to speed the process. Use a razor, such as in a paint scraper made for cleaning windows, or a straight edge razor held at an angle against the glass to scrape the film off. Use your blow dryer and spray bottle to continue spraying the film until it separates easily. Use your paper towels to mop up the water/ammonia mixture that gathers at the base of the window so the wood isn't softened or damaged by the moisture.
Step 4-Clean The Glass
Once the film has been pulled off, clean the glass thoroughly with an ammonia based cleaner to remove all traces of the old adhesive. If you plan to apply a new window tint after removing the old, clean the glass thoroughly with clean water and a non-ammonia or non-vinegar based cleaner to make sure the new film is not damaged by trace chemicals remaining on the glass from your last removal.
 forum activity
