cancel
Job type :
Zip Code :
community forums
comments
Repair Broken Plastic Curtain Rings in 2 Steps
As your shower curtain gets older, so do the plastic curtain rings that hold up your curtain. Some of these rings might have even been around before you moved into your home. Here are 2 incredibly simple steps that you can utilize when you are replacing those worn down shower rings.
Replace ALL rings
Do not just take a few worn down rings and replace them, if you are going to buy a full set of curtain rings, then why not replace all of the rings? Think about it, at one point or another, those other rings are going to start to wear thin as well. Take it up to the next level and replace everything. Plastic shower rings are designed to last for years on end, which is why you should remove and replace them all.
How to Replace
Replacing these plastic shower rings is incredibly easy due to the fact that they are made out of plastic. In order to remove your shower curtain, you will snap the rings open and take them off of the rod. Once that is all done you can put your shower curtain back up with the new plastic rings!
member comments
Related Articles
Brick FAQsBrick FAQs
Frequently Asked Questions about brick architecture... read more
Basement Remodeling - Visualizing Your Space
Here we will discuss ideas for a basement remodel - ideas, tips and general information... read more
FAQs About Floor CoveringsFAQs About Floor Coverings
Questions and info on floor coverings... read more
articles we like
Microlam
Microlam, also known as Laminated Veneer Lumber (LVL) or Lambeam, is a fairly new improvement... read more
Magnificent Minestrone Soup
Minestrone soup is a thick, delicious, and filling dish. It is quick and fairly easy... read more
Five Can't Miss Tips for Brightening Your BathFive Can't Miss Tips for Brightening Your Bath
Most homeowners know by now that improvements to bathrooms can bring big returns on investment... read more
sponsored articles of the day
diy centers
