Repair Roof Flashing: Tips for Clay Tile Roofs
If you want to save your home from water damage, you need to repair roof flashing on your clay tile roof regularly especially if you live in an area where weather conditions can be harsh. With the right tools and some working knowledge about roof installation, you can repair clay roof flashing like a professional. To help your repair roof flashing on your clay tile roof, here are some useful tips.
Pay Close Attention to the Chimney and Vent
When installing flashing on your clay roof, you should pay close attention to the areas around the chimney and the vent pipe. Make sure that your flashing extends about 6 inches on the side of the chimney to provide efficient drainage. To prevent water from seeping through the area around the chimney and the vent, install counterflashing to seal off the overlap located near the wall of the chimney or vent.
Provide Enough Valley Flashing
A well constructed valley flashing can serve as efficient channel for snow to minimize ice build up problems on your roof. For best results, your valley flashing should extend around 10 inches to 12 inches under the clay tile of your roof.
Use Cleats on your Valley Flashing Sections
To make your valley flashing more flexible and able to withstand extreme temperature changes, you should consider installing the flashing with cleats.
