Login Error
Close
Repair Your Car Door Lock In 4 Steps
by DoItYourself Staff
If your automatic lock isn't working, here are 4 easy steps to repair car door lock.
1. Check the Least Obvious First
It should be the most obvious, but most of the time we simply don't think of the auto key lock on our keychains. Called a key fob, it is operated by a battery that does wear out after several years of use. Replace the battery and then check it out by unlocking your doors.
2. Check Other Door Locks
Before rushing to rip off the door panel and replacing wires and parts, check the other locks. Do they work? If not, then you have a blown fuse. If they do work, the problem is most likely in the door lock solenoid.
3. Work the Lock Manually
While the key is on, work the door manually up and down while using the auto lock at the same time. If the lock tries to move, then it is a frozen lock mechanism.
4. Move Door Back And Forth
Hold the lock button down while you move slowly open and close the door. If the lock works then you have a broken or frayed wire that needs to be changed or repaired.
Try these tips for a quick way to repair car door lock. If these tips do not work and you can't find the problem, see a mechanic.
 forum activity
