Repairing a Light Fixture Wire
what you'll need
- A new lightbulb
- Voltage tester
- Needlenose pliers
- Flathead screwdriver
- New switch
- New light fixture
You don’t have to be a professional electrician to troubleshoot and repair a light fixture wire. Most problems with light fixtures are caused by the light bulb, the fuse or the switch. The following is a step-by-step guide to help you isolate and repair the problem. You may need some or all of the following items to repair the light fixture:
Step 1 - Test the Bulb
Remove the light bulb and install it in another fixture that you know is working. If the bulb does not work, remove it and dispose of it properly. Install a new bulb first in to the fixture you know works, and then into the faulty fixture. If the light turns on, mission accomplished!
Step 2 - Check Power at Fixture
If the good bulb does not work, you will need to test the outlet with a voltage tester. Press one end of the tester onto the brass contact at the center of the fixture. Connect the clamp on the other piece of the tester to the metal part of the fixture. If the fixture is working properly, the tester will buzz and light up. If this happens, replace with a new bulb.
Step 3 - Check Circuit Breaker
If the tester does not light up and buzz, there may be an issue with the circuit breaker. In the breaker box, each circuit should be labeled to the corresponding areas of your home. Check to see if the breaker has not been tripped. If the breaker is set to off, simply reset the breaker by sliding it to the right.
Step 4 - Test Wiring
If this does not solve the problem, check the wiring at the light switch box. Turn off the correct circuit breaker in question. Use a small, flathead screwdriver to remove the light switch cover plate. Do NOT touch the wires before first using the voltage tester to see if any of the wires are still hot. Then check to make sure the wires are correctly fastened to the switch terminals. The wires should be wrapped around the screws on the side of the switch, and screwed down securely to the terminals. Return the faceplate cover back over the switch. Turn the circuit breaker back on and test the light.
Step 5 - Replace Switch
If the light still does not work, turn the circuit breaker back off. Remove the faceplate cover and replace the switch with a new switch. You will want to make sure the new switch has the same amperage and voltage ratings as the previous switch (as well as the same color as the faceplate). Be sure to properly wrap the wires around the correct terminals and screw the terminals down. Turn the circuit breaker back on and test the light.
Step 6 - Replace Light Fixture
If the light still does not work, there may be an issue with the wiring in the light fixture itself. Turn the circuit breaker back off and remove the light bulb from the fixture. Remove the cover for the fixture and make sure the wires are properly secured to the terminals.
These steps should repair any wire issues in a light fixture. If this still does not work,it is recommended to call an electrician.
