Repairing Cracked Tiles
Repairing cracked tiles does not require you to be a professional though the work involved may require quite some cleaning up after you are done. When there are only a few cracked tiles that need to be replaced, and you have the required replacements, you can certainly go ahead. It is however, a much harder job if extensive tile damage has happened. In those circumstances professional tile repair services are most advisable. Not only will the job in your house be quickly done, the end result will be pleasing to the eye.
Chipped and cracked tiles are the some of the most common types of tile damage that are faced in the home and the remedy usually involves a complete replacement of the affected tiles. Some homeowners keep a number of tile replacements in their stores just to be safe and ready when any cracked tile requires to be substituted.
Basic Steps in Cracked Tile Replacement
Replacing a cracked tile involves you preparing a suitable amount of grout and then laying it on the required surface. You then affix the substituting tile on the prepared surface and allow it to get firmly attached. In the event that substitute tiles are not available, another option may be to use the same loose tiles while bonding them with specifically prepared liquid adhesives. In this method of cracked tile repair ,you will drill holes into the grout that is sandwiched between the tiles and then inject liquid adhesive into them. After the adhesive has set you will then fill the holes with grout.
Repairing Damaged Caulking
Part of your job in ceramic tile repair may involve restoring damaged tile caulking. Ideally, a tile is resilient to water damage largely because of the glass glazing process that they undergo. The problem arises when the tile itself cracks. This situation permits water to penetrate to the underlying caulk and in some circumstances this material may become moldy. Such situations are observed mostly in the bathroom area and if left unattended the problem may extend to a wider area thus more damage. To take care of this problem you simply have to prepare some fresh caulking for replacement. You are best advised to acquire caulking that has anti-mildew capabilities. Better protection can be afforded when you top this up with a slight layer of mildicide.
Re-grouting
When it is the tile grout that has been damaged through cracking, re-grouting is a viable option to consider. Proceed to prepare suitable amounts of the requisite grout and then use it on the affected surface. When it has adequately cured, you can protect the grout from water damage through application of a grout sealant that can be obtained from hardware stores. From the same stores you can also purchase porcelain fillers which are handy when replacing chipped or cracked tiles.
