Replace a 3 Handle Shower Faucet Diverter Valve
what you'll need
- New diverter valve
- Plumber's Teflon tape
- Adjustable wrench of channel lock pliers
- Screwdrivers
If your three handle shower faucet is not properly diverting the flow of water to the shower head and bath tub spout the way it should, you should replace it. Replacing the diverter valve in the system is a straight forward task and is great for DIY enthusiasts. So, here is a handy how-to guide to help you replace the diverter valve in a three handle shower faucet system.
Step 1 - Cut Off the Water
Turn off the main water supply to your home by going to the front of your home in locating the water supply valve. It should be located at ground level in front of your home and is the area that the water company uses to check your meter. To close the valve, simply turn it clockwise until it is completely tightened and the water pressure has been cut off.
Step 2 - Drain Water in Lines
You also need to drain the water from the lines in your shower to avoid a mess while working on the diverter files. To do this, simply open the faucet all the way and allow the water to drain out the spout or shower head.
Step 3 - Cover the Drain
When working on the diverter valve of your 3-handle shower faucet, there are several small pieces that could fall down the drain. So, cover the drain opening in your tub with a object that will prevent this from happening.
Step 4 - Remove Cartridge
The cartridge is a section of piping that is used to connect the handle of your faucet to the plumbing behind the shower wall. The front section of the cartridge is used to connect to the handle and turns whenever you turn the faucet handle. The back part of the cartridge connects to the diverter stem valve, and is used to direct the diverter on which way to open or close.
To get to the cartridge, you'll probably need to pry off the face plate of a handle to access the screw. You can do this with a flat head screwdriver. Remove the screw and then the handle. Also remove any escutcheon rings or faceplates that may be blocking access to the cartridge and diverter valve. Remove the nut that holds the cartridge in place and then slowly pull it out from the shower wall.
Step 5 - Remove Diverter Stem
Step 6 - Install New Diverter Stem
Step 7 - Replace the cartridge
Finally, reinstall the cartridge in the reverse order that was used to uninstall it. Then, you can replace the handles of the faucet and turn the water back on. The new diverter stem valve should now function properly and direct the flow of water the way it was intended.
