Login Error
Close
Replace Siding with Brick: What to Consider
by DoItYourself Staff
If you want to replace siding with brick, what are the things that you have to consider? A house siding is employed for both functional and aesthetic purposes. Siding serves as a house’s protective suit of armor. Siding protects the house from harsh elements brought about by the weather. Siding is usually composed either of shingles, sheets, or several boards. All these materials aim to keep out wind and rain from seeping into the interior of the house. Siding materials are made to overlap each other, and are firmly interlocked and sealed at various points of the housing structure. Siding also enhances the aesthetic appeal of the house, and can be customized to fit a certain theme.
There are times when you may opt to change your current siding with another type of siding. This happens when the current siding is old and worn, or if you simply wish to change the overall look of the house. If you want your current house siding to be replaced with brick, there are many factors to consider before you make a decision:
Current Siding
It’s important for you to first identify your current type of siding before replacing it. Some sidings may not be easy to remove, while some sidings come away readily under the right procedures.
Define Your Budget
Keep in mind that brick siding is expensive. Aside from shelling out money to remove your current siding, you would also have to invest in the brick materials to be put on your new brick siding.
Determine the Color of the Brick Siding
Although brick sidings usually come in red, you can choose from other color tones in order to make your new brick siding unique.
 forum activity
