Replacement Basement Windows: Can Hopper Units Replace Vinyl?
If you are trying to choose the proper replacement basement windows, you could use hopper units to replace vinyl. When you take out the vinyl and replace them with hopper units, you need to make sure that you install them correctly. It is very important that you get the hopper units to fit in the opening and get them effectively sealed up with caulk all around the outside edge. As long as you take your time and do it correctly, hopper units should serve as an adequate replacement for vinyl.
