Login Error
Close
Buying Replacement Fireplace Doors - Things to Look For
by DoItYourself Staff
If you are looking for replacement fireplace doors you need to be careful while selecting from the multiple options available to you.
Your choice of replacement fireplace doors depends largely upon your requirements including the type of existing fireplace, children and pets in the house, affordability and aesthetics.
The type of fireplace you have is important because the replacement fireplace doors must shut extremely tight. If you have a brick and mortar fireplace then you should look under the category of masonry replacement fireplace doors. On the other hand, if you have a pre-fabricated fireplace or the chimney is enclosed in a vinyl sliding you will need zero clearance fireplace doors.
If you have small kids or pets in the house you will have to consider a set of replacement fireplace doors with a screen.
Consider your budget as there are many types of replacement fireplace doors available in the market. The price depends upon the type of material used. Anodized aluminum and glass replacement fireplace doors are cheaper than brass doors.
Home décor is another thing that you should take into account. Choose replacement fireplace doors that complement the existing décor.
 forum activity
