Login Error
Close
Replacing A Plank: Laminate Flooring Repair
by DoItYourself Staff
Finding the plank laminate flooring that you need to replace a damaged plank is as simple as ordering extras from the manufacturer. In fact, it is a good idea to have a few extra planks when you install your laminate flooring that can be used as replacements in the event of damage. Extra planks will also come in handy if you make inprecise cuts during installation or if you underestimate the size of the room. Having them on hand will reduce the expense and time of having them delivered.
Repairing a Plank or Replacing It
Many scratches in laminate planks can be repaired with kits that match the color of your floor. Only remove and replace laminate planks when the damage is extensive.
Replacing the Plank Laminate Flooring
First, determine the closest wall or start point to the damaged plank. Laminate flooring is connected, which means that you will have to remove all of the planks from the damaged one to the starting point against the wall. Remove the baseboard near the wall and start removing the planks leading to your damaged one.
When you arrive at your damaged plank, you can simply take it out and put in the replacement plank. Then work your way back to the wall and put the baseboard back in place. If you are careful when removing the baseboard, you should be able to reuse the existing pieces and not have to replace the baseboard as well.
Caring for Your Laminate Flooring
The best way to avoid replacing plank laminate flooring is to prevent the damage from occurring in the first place. Take care to use furniture protectors on your heavy pieces, and never drag a piece of furniture across the floor. Always lift furniture up when moving or rearranging a room.
Keep moisture away from your flooring as much as possible to prevent water damage. Laminate flooring is very resistant to damage, but it is not impervious. You can avoid a lot of problems by simply keeping your floor in good shape and free of moisture.
Loose debris is a problem for hardwood floors because it can scratch the finish. To avoid the same problem with laminate flooring, even though it is tougher, keep loose debris swept up and off the floor. A little bit of prevention will go a long way in keeping your plank laminate flooring in good condition and avoid having to replace a plank in the middle of the room.
 forum activity
