Replacing Bathroom Cabinets
If you're remodeling or upgrading your bathroom, replacing your cabinets is a great way to boost your home’s value and give you a fresh look that you can enjoy.
When it comes to remodeling your cabinetry, it seems like there is no end to the array of options that are available to the homeowner. Sure, there are the obvious options such as deciding on a certain color or a favorite wood, but what about other options such as doing the job yourself versus hiring a contractor, or choosing to buy all new cabinets or just giving the ones you have a face-lift? You'll want to make thse decisions before you go to the home improvement store.
Determine Your Project
If your cabinets are still in good condition, and you like the layout and storage you already have, just replacing the doors or hardware might be a great solution for you. On the other hand, if they have seen better days or you want to add more storage or counter space, completely remodeling may be the better choice.
Giving Your Cabinets a Face-lift
If you’re looking for a fresh look for your bathroom and you’re on a budget or you’re comfortable with the way your storage is laid out, there’s no need to gut all your cabinets. With a little elbow grease and not much more money, you can totally change the look of your bathroom without throwing away good wood. Sanding off previous finishes will allow you to refinish the surface in a new color and texture. Replacing worn hardware such as new decorative handles and damaged hinges can breathe new life into your bathroom at a fraction of the cost.
Out With the Old…
Sometimes cabinets are beyond repair and need to be replaced, or possibly you’ve outgrown your storage capacity. The great thing about new cabinetry is that you can custom design the layout the way you want. If you are unsure of a layout that would work best for your application and needs, most cabinet retailers or builders offer design consultation when you purchase from them. They can help you narrow down your choices and let you know if certain options will interfere with other elements of your bathroom, such as doors, sinks, or toilets. They may also have designs, finishes, and hardware not typically available for do-it-yourselfers.
Do-It-Yourselfers
If you have the right tools and think you’re up to the task, you can save lots of money installing your own cabinetry. Floor cabinets and counter tops can be pretty easy to install with a little bit of basic home repair knowledge, but more complicated designs and pieces that hang from the wall are best handled by an exert installer. If your bathroom project is more work than you want to tackle, check into one of the many cabinetry professionals in your area.
