Replacing Metal Bunk Beds
Replacing metal bunk beds should not be a chore whatsoever since a variety is readily available. Although wood bunk beds are quite popular, metal bunk beds offer quite a bit of choice especially if you want to change or update the look when replacing them. Since there are so many choices available to you, doing a bit of homework will give you enough knowledge to make an informed decision. Once you’ve surfed the net looking for replacement metal bunk beds and have decided which to buy, you’ll need to dispose of the old set properly.
Disassembly Is Best
Unless you plan to move the fully assembled metal bunk beds to another room in the house or transport it to another location, you will need to take it apart and dispose of it properly. Most metal bunk beds are purchased unassembled, so hopefully you will be familiar enough with the product to easily disassemble it. Make sure to unscrew all bolts and fasteners carefully. Remove all sections of metal that form the frame of the bunk bed. These metal lengths may have sharp edges, so when disposing of them exercise caution.
Purchase Assembled
Check with your local retailer to see if you can purchase a replacement metal bunk bed that comes fully assembled and delivered.
